Yamaha Tach Problem
Boilermaker1
Help Needed Yamaha Tach
I just purchased a 2007 Yamaha F60 CET, The tach is not functioning right. It counts revs fine but tilt and trim is always on a single bar and alarms do not work. The tach has a four pin plug and for wires that go to the 703 control unit. the wire colours on the tach plug are, Pink,green/red,green/white and grey..The are two four pin plugs on the harness and the wire colours are, green/red,green ,pink and grey.. the engine had a four pin plug and wire colours are , Pink, 2 Pink/black,pink/white..I have photo's of all the parts, Photo 1 Engine plug. Photo2 harness plugs, Photo3 Front of tach. Photo 4 tach plug. Please help​
No part number on the invoice? It isn't the correct part so you should get some help from the dealer you bought it from.
the meter you are showing in the picture is for 2stroke oil injection model, coz oil injection model has separate oil tank indicator but the indicator with tach meter. option 1;- change the meter
option 2;- you have to modify the meter wires ( not recommended).
