I have a 2006 T8 kicker motor on my boat (no hour meter but estimated about 10 to 12 hours run time). I bought the boat used about 6 months ago. The boat is very clean and was well taken care of. When I bought the boat I checked all of the fluids for level and condition. Both my big motor and the T8 kicker were full of oil and the oil looked pretty clean (low hours). Yesterday while drift fishing the river I was using the kicker to run back up to the top of a hole. about half way through the day when I would start to idle down, the engine would start cutting out and run really rough. I would feather the throttle and it would come back. It progressively got worse as the day went on and eventually got to the point where it would cut out while running up river at full throttle. If I turned off the motor and then started it right back up it would run fine for about 4 or 5 minutes and then it would do it again. When I got home I started checking over the motor and when I pulled the oil dip stick there was no oil on it. I drained the oil and it only had about 8 ounces in it. (it's supposed to have 27 ounces) I did a compression check and both cylinders are at 166 psi (I don't know what factory specs are). When I look into the spark plug hole with a flashlight, I can see a lot of carbon build up on the valves as well as on top of the pistons. It appears to me that the motor is burning a lot of oil. Until yesterday the motor ran like a top. And even yesterday it ran great except for when it would cut out. I read where the T8 has a low oil pressure safety built in and the motor will drop to 2000 RPMs when low oil pressure is detected. I'm sure this is what was happening yesterday. So my question is....why do you think it would be burning oil and do you think I need to rebuild the top end (new pistons, rings, valves)?
Thanks in advance for any help.
