rick.lucas@cooperservices
I have a 2016 Yamaha 250 with 112 hours of run. Unfortunately, I was unable to run it much since i was unable to run it much while the warranty was still on.. The engine failed after 112 hours of run. Through the #1 piston rod through the block. The rod appears to have bent from what appeared to be crystallization and cocked the pistons over, the rod then pulled the piston pin though the eye and as it was doing this, it broke the rod.
Trying to even communicate with Yamaha, they were were like ostriches sticking their head in the sand and not even attempting to be honest and find out what the reason was.
The distributer pulled the computer data pre failure, and all showed up to be good.
I researched the web and found another guy that lost his at 98 hours and Yamaha tucked their heads there also. The only difference, I believe was Yamaha made a change in the 250 engine configuration around the time of our purchase. They moved the 3.3 Liter to a 4.2 liter.
It is amazing how a company of this size would not even attempt to find the Reason.
I work as a SR. Engineer for a OEM that has built natural gas engines since 1833 and we have stood behind our product when our engines are worth millions.
