" I just found this board lots
" I just found this board lots of good info.purchased 1989 yamaha pro 50 last fall,it had been sitting for over a year.removed the carbs. 3 times and cleaned,motor cranks good and runs good to about 4000 rpm starts to bog, I can pull manual choke out about 1/4 way and the motor picksup and runs good at about 5200 rpm. also replaced primer bulb, gas line and checked fuel pump for hole.have tried to pump bulb running down the water but it is tight.
thanks for any help!!
robertmg "
robertmg "
