Yamaha/Mariner 15M 684cs 018642 impeller change
steveus
Hi to all, some of you have helped me out tremendously in the past. Just changed impeller, had ordered Sierra water pump repair kit 18-3148. I may have read it wrong, but all of Sierra's info seemed to reference me to this kit #, although it says on it Yamaha 682 whereas my motor is 684.
Anyway, I installed impeller, but literally had to hammer it on the shaft with a pipe, all the way down. Very tight fit. Did get the key in, and is pumping water. Did I get the wrong impeller?
Big problem, just because I didn't know what I was doing, shifting will not go into reverse. Neutral and forward fine. If someone can give instructions that would be appreciated. Will I have to take foot off again to adjust this to proper position? Getting the foot off was no problem.
One more question, would the Seloc manual 2-60, 1997-1989 have shown me how to reconnect shift rod properly? I am going to order one, but was concerned that it covers so many models.
In advance, thanks for any help. Thanks,
Steve
