Yamaha F60TLRA 2002 not charging changed rectiefier/regulator made no diff. does somebody have test numbers for stator thanks
dougmowat
YamahaF60TLRA does not charge changed rectifier / regulator becauseit was cheap , does anyone have test numbers for stator thanks doug
tested 3 Green wires to 3 pin from stator with noharness 1-3 is 1.6 2-3 is1.8 1-2is 1.6 other 2 wires from stator brown and blue 321.4 ohms
If I knew anything about Yamaha I'd try to help. I think the reason you aren't getting much response is that this is a general maintenance and repair section. I'd bet that if you post this question in the Yamaha section you will get a better answer.
Good luck!
