Hi, I have just bought a motorboat with an Engine with an known issue but the cause is not found.
It starts up fine but it makes a metallic scrambling sound that of course does not sounds good.
I know that it could be "anything" and its is inmpossible to tell without more information but I talk generally here, what known mechanical problems are there and how likely are they?
F.ex. A failing Crankshaft Bearing, how likely is it compared to a broken Piston Head Packing, etc. etc you get the point
Q1 does this model have any typical known mechanical/material problems with crank shaft bearings, piston seals, spur or beavel gears?
Q2 What is the most likely causes and how could it be fixet?
Please dont reply like "are you stupid, how are we gonna tell you the problem with yor engine out of that", please bear in mind that I asks the most likel y casuses, not whats the exact casue is
Thanks for your time ..
Bo
www.eddievan.com
Bo
www.eddievan.com
