Reaching out to anyone who can help shed some light on a recent problem I've encountered with my old friend the Yamaha F115TXRC model. Recently the engine created a rough idle and eventually wouldn't start.....after checking the fuel lines and replacing the separator I was able to get it started again and it ran fine for a 30 minute run home WOT.....after putting the boat on the lift, still in the water, I tried to start it again with no luck.....so I proceeded with the following steps and results:
1) Changed the Low Pressure fuel pump first off.....engine ran great again for 20-30 minutes and after stopping and killing the engine multiple times it started right up.....but after shutting the engine off for about 15 minutes it would crank but wouldn't turnover/start again....also when trying to start after a 15 minute off period, the bulb was slightly soft and not as hard when as it was when I first started the engine w/o a problem....
2) Spark Plugs checked/replaced....not real bad but replaced none-the-less...in line fuel filter replaced inside the bottle....mid line fuel filter replaced between the Low Pressure pump and the VST....and the thermostat was replaced....engine ran great again for 20-30 minutes and after stopping and killing the engine multiple times it started right up.....but after shutting the engine off for about 15 minutes it would crank but wouldn't turnover/start again....also when trying to start after a 15 minute off period, the bulb was slightly soft and not as hard when as it was when I first started the engine w/o a problem....
3) Replaced the IAC and the Fuel Pressure Regulator the next day.....engine ran great again for 20-30 minutes and after stopping and killing the engine multiple times it started right up.....but after shutting the engine off for about 15 minutes it would crank but wouldn't turnover/start again....also when trying to start after a 15 minute off period, the bulb was slightly soft and not as hard when as it was when I first started the engine w/o a problem....
4) Removed and thoroughly cleaned the VST, replacing the High Pressure fuel pump and cleaning the needled points etc.....engine ran great again for 20-30 minutes and after stopping and killing the engine multiple times it started right up.....but after shutting the engine off for about 15 minutes it would crank but wouldn't turnover/start again....also when trying to start after a 15 minute off period, the bulb was slightly soft and not as hard when as it was when I first started the engine w/o a problem....
5) Replaced several runs of fuel line and the bulb.....engine ran great again for 20-30 minutes and after stopping and killing the engine multiple times it started right up.....but after shutting the engine off for about 15 minutes it would crank but wouldn't turnover/start again....also when trying to start after a 15 minute off period, the bulb was slightly soft and not as hard when as it was when I first started the engine w/o a problem....
6) Injectors pulled during VST cleaning and the injectors got a thorough home style cleaning, one was plugged and cleaned out nicely....engine ran great again for 20-30 minutes and after stopping and killing the engine multiple times it started right up.....but after shutting the engine off for about 15 minutes it would crank but wouldn't turnover/start again....also when trying to start after a 15 minute off period, the bulb was slightly soft and not as hard when as it was when I first started the engine w/o a problem.....yes, I have thrown enough parts at it and am seeking support and any ideas before I throw anything else at it...
Does anyone have any ideas on what else should be checked or replaced? Why would it run so great after anyone service task and then limp out and fail to start again after sitting 15 minutes....any help appreciate.....Thank you.
