Yamaha F100D charging rate
Blake49
Hi,
I know the Yamaha F100DET has a max charging output of 20amps, I am trying to find out at what RPM this is and also how many amps it will put out at idle?
Thanks for your help
Blake
The service manual lists two specs -
@1000 rpm 12 volts/12 amps
@6000 rpm 12 volts/20 amps
Between the high/low rpms the increase/decrease in amps is "not linear" (so maybe 19 amps at 5K and down to 14 at 4K etc), but at the minimum you can count on 12 amps...
