Yamaha 90HP 2 Stroke Lower Unit Removal
binspector
I have a 2001 Yamaha 90HP 2 stroke. I am getting ready to replace the water pump and I have watched several videos. In none of the videos do I see anyone disconnecting a shift rod. I have changed a few water pumps in other engines that required the shift rod to be disconnected in order for the lower unit to drop down. When I see the videos it seems all that's needed is to remove the bolts that actually hold the lower unit on. Is this correct or am I missing something?
Thanks!
Bryan
yam 90 doesn't have a shift/drive shaft connection. The shift shaft slides in/out of drive shaft tube. Smaller yam hp engines has the shaft connections you refer to. The woodruff key can present challenges, fyi. Before dropping LU I recommend getting a service manual model/year specific to your engine.
