Yamaha 90 aeto electrical gremlin
seadogg
Evening, I have an odd one that I cannot get to the bottom of...
Couple weeks ago my tilt/trim motor cut out on the way up and the engine started cranking without the key in the ignition switch. After some checking and head scratching i got the trim motor to fucktion normally bypassing the relay and the engine to crank bypassing the solenoid.
I just fitted a few relay and solenoid and neither work without bypassing them again. I tried fitting another ignition switch I have but it still does the same.
Everything works but only when bypassed
Any ideas?
Cheers
What is the engine serial number?
Did the motor start cranking itself at the exact same time the trim motor stopped working?
