Most of the model number is missing so I hope what I have is enough. It is a 4 cycle and has the Solenoid on the top of the Carb. Does that work as the Choke, and if I put voltage to it out of the Carb should the rod move? If you put your hand over the horn it will start and run as long as you keep it partially choked until the engine warms up then it is fine. I see the solenoid is expensive and want to be sure before I order one. This is the part number and description [h=1]6G8-1410A-01-00 STARTER SET.[/h]
Thanks everyone
Thanks everyone
