Yamaha 85 aet model 2011 question
Mahdi
Hellow
Yeaterday i open the prop for cleaning fishing lines & re-greasing the prop shaft then i try it in the sea everything was good and working geat after 1 hour the prop not respond with the leaver when i push it forwoard or rverse when i back i open it again but the prop shaft is stuck its not turn can you help me what is the proplem?
And what can i do? Didnt find any video on youtube about this problem :(
Sounds like your shift cable is broken and motor is is gear.
This happened to me this year after using the motor all day. I could move the shiftier under the hood be make it back to the ramp.
thank you for replay slipcork the shift rod was stuck i turn it to nutral and the propeller turnd normally ! but why its stuck at first??
is that becouse the rod is dameged?
