Hi when on the water the engine sometimes will crunch and not go into reverse, when it does go into reverse the engine will accelerate quite hard straight away (a lot more then when you put into forward). When on the trailer with the gear cable off it goes in fine but its like a double push. When you go into forward it goes straight in, for reverse you push it back then back again to get it in. The cable will push the gear pin all the way back with remote. I think it maybe a remote problem as it has other issues that could be caused from it too but the remotes so simple I cant see anything.
