Hi.
So my motor pumps water ok. The tell tale starts strong and as it warms up it goes to a ragged spray. Water is also dripping out of two holes on the underside of the motor either side of the tell tale hole. If I block the tell tale with my finger, more water pours out of these holes and the plastic undercover of the motor. There is no water at all in the cowl.
Is it normal for water to leak from these areas or should it only come from the tell tale?
Thanks.
Mark.
Thanks.
Mark.
