ppidgursky
"I could really use some help
"I could really use some help here fellas.
When I start the motor she will run ok for a second or two then the noise comes. Almost sounds like gears or something metal rattling. The sound sounds the strongest on the left side, near the bottom of the motor. I removed the foot and checked the spines on the shaft...they are fine. I checked the oil in the foot it was low, and milky so I changed it. Still happening. If the foot was leaking oil, where would it leak from?
When I rev it up some, it clears up. Maybe 2-2500 rpms and up. This happens in and out of the water.
I rebuilt the motor not to long ago, and she was fine at first. The rebuild went smooth I guess. Everything put back together ok and smoothly. What could be wrong.. or do I need to tare it down again?
History:Motor is a Yamaha 1989 50ELF.
Have had the block bored 20 over, new pistons, rings, fuel pump, carbs rebuilt, new fuel lines, rebuilt water pump, new batteries, new gaskets and orings all the way around."
