H folks,
I have (had) a reliable 1999 40hp Yam 2 stroke with little hours. We hadn't run It since last year but it had been winterised and turned over monthly. I serviced it yesterday, gear oil change, impeller change, new plugs and new filter but when tested it is constantly in forward gear. All mechanisms under the hood are operating smoothly and engine is running/pumping water as is should.
We had the tail off today and it seems the gear selector/ changer (in front of the impeller) doesn't select gear or neutral. When we turn dial when we're spinning prop there doesn't seem to be any change.
Is there an issue with the gear box? Have I done something when I took tail off to change impeller?
Any advice would be most welcome. I have two kids desperate to get some creels out.
Ta Russ
Ta Russ
