Hello. I have a Yamaha 40hp 2 stroke (3 cyl) engine from early 80's somewhere. There are no numbers on the engine, so I'm not sure what model exactly.
Before the boat season ended the engine ran very rough. Especially on idle, but it also made some noises in higher RPM's too. Also I felt it was using more fuel, but significantly loss in power. About 6-8 knots slower on full throttle. It also seemed like it was leaking some fuel or something too. the ocean didn't look too good when the boat stood still and engine was idling.
I've taken the engine into my garage for the winter and taken out the carburetors and cleaned them.
I let them lie in diesel for a day or so and cleaned them with a little brake cleaner (it's hard to find carberator cleaner over here) I also took out the reed valves and cleaned them lightly.
I fired up the bad boy today and it still runs rough and coughing.. A lot of smoke too.
- I've checked for sparks, it seems pretty fine. Good clear sparks
- I've had a compression check on it too some hours ago. Looks very good. Even compression on all 3 cylinders.
I also noticed that on cyl 2 and 3 fuel is leaking out of the choke plate. So I feel the problem is here or something with the carburetor adjustment.
On the bright side it's VERY easy to start the engine. Therefore I don't think it's a mechanical issue inside the engine.
I'm REALLY hoping I can get some help here.
Cod season is in full bloom right now and the ocean here in norway is crawling with fish atm! It won't be long before it's over!
just fyi I'm not a marine mechanic and have not worked so very much on 2 stroke engines, but I am an automotive mechanic so I've got some skill in this area.
