Hello all. I'm new here and I am all out of idea's but i thought if anyone can help it would be here. I'll cut a long story short. I bought a second hand yam 30 about 1991 vintage, 3 cyl version. Pull start only, very basic but for my needs will do fine. I'm not a complete novice as my other boat has a Suzuki DT40 on it so i have learned much.
Anyway, I bought the engine and got her to fire up, bit smokey, didn't like idle etc but ran smooth other than that. Pull starting was quite easy. It needed work so I changed the impellar and water pump housing ( done this before) and it needed a new shift linkage aprt and engine to lower case gasket. Did all this, screwed it all back together and went to start it. VERY stiff pull start, no way can I pull hard enough to get it to fire. Pulled the plugs out and no worries, smotth, free as a bird. Trid throttle open/shut choke on/off, nothign makes much difference. removed the pull starter and thats free as a bird too. I have read about a relief valve but not sure if mine has one or even where it would be. Any help would be greatly appreciated.
