I'm rebuilding a 2005 Yamaha 25 horsepower 2-stroke outboard I have it tore all the way down to the crank.
My question is on the lower seal housing inside there are two seals that fit over crank shaft. The seal on the upper bearing said use locktite 271 which I used. The repair Manuel says nothing about using locktite on the lower seal seals. I would assume since it says nothing about it don't use it but I just want to make sure I'm doing the correct thing
