Hello all, I am looking for someone who can help me with my new motor.The motor is in great shape and seems to work as intended. I recently installed it on my current boat and i use the manual tilt lock lever to raise and lower the motor. Please help me as I am not sure how the tilt lock lever is supposeto work. I read the manual but it doesnt not give much explanation. I do believe you must tilt the motor up to a certain angle for best results in speed and power? I took the boat out for its first test run after new motor. I adjusted tilt trim manually to where I thought it looked level. Everything worked great until I applied full power then the motor sunk all the way down. The boat achieved good speed but the with the motor sunken completely down it seemed like it was angled way too far down into the water. I am unsure how this tilt function is intended to be used and if I am doing correctly or not. Looking for an expert who can give me some insights. The piston does not sink over time and I can not force it down by applying my own weight to it so it seems it is fuctioning properly. I suspect it must leak or have air in it and cannot sustain the load of the motor under full power. Any help diagnosing this would be greatly appreciated!
