BillFlynnSr
I have a 2003 VX250. Trouble starting after arriving on flats, engine turned off for some time. Symptom fuel pump doesn't always turn on when I turn on ignition key, thus engine won't start. Doesn't always happen. Mech ran some tests load side of stator only putting out 9.7 volts should be a minimum of 100 volts. Would this stator output problem cause the fuel pump to not come on? We aren't sure. With the load side output so low we don't think the batteries are not being fully charged, so could running trolling motor lower battery charge level enough to prohibit the fuel pump from running?
