Yamaha 2001 50 hp Outboard Motor
tinyg
Hi I have a 50hp Yamaha outboa
Hi I have a 50hp Yamaha outboard motor there are three carbs on it. The middle carb is leaking gas out some holes. Does this mean the carb need rebuilding. Or the jets stopped up
Sounds like bad float or debr
Sounds like bad float or debris in valve remove and inspect check float for cracks or worn needle tip
