Hi there.
This motor is driving me crazy!
Heres the fault: After running for 10mins, if we drop to idle for 10 seconds then pin it. The motor accelerates onto the plane fine and up to desired speed. After about 15 seconds. The motor drops by about 2000rpm for about 10 seconds. Then motor returns to correct and stable running rpm
This makes watersports very difficult..
Here's what I have done so far:
Carbs rebuilt, float levels correct.
New fuel filter.
New fuel pump.
New coils.
New plugs.
Replaced failed fuel hose.(collapsed lining)
Borrowed a good CDI unit. ( No improvement)
Fuel bulb goes hard
Temperature audible alarm works. Fault still occurs with thermocouples out of block.
Oil level audible alarm works
Battery good
Good water telltale.
Checked thermostat function in boiling water.
Cdi unit is CU2481.
Any suggestions are appreciated.
New fuel filter.
New fuel pump.
New coils.
New plugs.
Fuel bulb goes hard
Battery good
Cdi unit is CU2481.
