Thank you in advance for reading this post.
I was going to change my spark plugs and I had to remove the plastic cover that is bolted to the valve cover. Naturally the bolts were frozen. I used my impact hammer driver to free them up. I guess I hit one a little too hard. The bolt and the mounting piece that the bolt screws into went inside the valve cover. I have felt around with a magnetic reach and can not find it. I guess my question is what can I do if anything other than taking everything apart to get to it? I am not even sure I can get to it if The valve cover comes off. Can it fall deeper inside the engine?
Thanks Again
Thanks Again
