Hello all, My 1985 XP150 had a new VRO pump installed about 3yrs ago, the new VRO came with a wiring harness which the old original did not have. I installed it per instructions that came with the VRO pump and all was good until 3 weeks ago. After about 30 minutes of 3/4 throttle running I slowed to go through an Idle speed zone and shortly after opening the throttle after clearing the zone the VRO oil horn (beep every second) started sounding and I shut it down and checked the tank and oil bulb tank was full and bulb was firm. I limped to a nearby ramp with the trolling motor and hitched a ride to get the truck & trailer. I took it to my mechanic and dropped it off describing the problem in detail. Two weeks later I phoned him to see if he had looked at it yet and he told me that he had but he couldn't find anything wrong! So I picked it up this morning and took it to the lake put it in and ran the wassits out of it for about 45 minutes with no trouble! I ran it wide open, I ran it half throttle, I ran it at low speed, and it ran flawlessly! until I shut it off for about 30 minutes to do a little fishing. Then when I started up to run back to the ramp I got maybe 1/4 mile and beep beep beep! Once again tank had plenty of oil and oil primer bulb was firm. I could even see oil in the clear tube running to the pump. I'm seriously considering disconnecting the oil pump section and mixing my oil myself! has anyone ever heard of this problem intermittently? It was obviously pumping oil before the horn started going off or it would have locked up with all the running I did! Any suggestions what to check?
