Wrist pin removal
jeff777
So everything I read says my pistons in my 1982 35 hp Johnson will be marked showing the loose side for wrist pin removal. I can find no such markings on my old pistons or my new ones. Apparently they stopped doing this at some point??
Piston sitting upside down on the work bench..... If a loose w/pin side exists, you will be staring at a raised Capital "L" on the piston area housing the w/pin. If the "L" doesn't exist, you may have the new style piston that incorporates a floating w/pin hole, a machined fit whereas the w/pin simply slides out.
