Wont start
dutchman
I have a chrysler 318 which ra
I have a chrysler 318 which ran for a 20 minutes warm up. I took of the lines went down rive a bit and it stalled. It will crank but no start. Any ideas
Dutch
"If no spark, check red circui
"If no spark, check red circuit breaker on top at the back of the engine.
With ignition switch on and motor not running check the voltage at the + side of the coil. It should be around 6v. If no voltage check the upstream side of the ceramic resistor ballast. It should be 12v. If no voltage there you might need an ECU. It's the electronic control module and you can buy one at Walmart, Farm & Fleet or a discount auto parts store for under $20.
If you have spark, your fuel pump may have died."
