Wonbt stay on
emiliogarza
"I have a 85 HP Johnson-Model#
"I have a 85 HP Johnson-Model#85ETLR78C that will not stay on for more than 7 sec.I have a 50:1 ratio(new gas).I have new plugs out of the boxthat I put in.I also have sprayed the carb with Carberator cleaner and have removed the screw plug from the bowl to drain all debri.THat is all I have done,also I was wondering if the plugs need to be gapped?Still waiting to go fishing,so hurry please."
"Spark plugs should be Champio
"Spark plugs should be Champion QL77JC4 plugs, gapped at .040 .
Spraying the carburetor is a waste of time. All you're doing is shooting the cleaner directly thru the throat into the crankcase.
If you have compression and spark (100+ psi) (spark jumps a 7/16" gap w/plugs removed), remove, dissmantle, clean, and rebuild the carburetors.
Be sure to manually clean the slow speed and high speed jets."
"As Mr. Reeves says, carbs pro
"As Mr. Reeves says, carbs probably need to be removed and throughly cleaned."
