OK. With your help and advice, I have discovered two problems with my motor. In trying to cure the stalling problem, I discovered my tank was not getting pressurized. I started by checking for air pressure at the hose barb on the reed valve plate using a pressure gauge. As the gauge works to measure both pressure and vacuum, initially, I read the gauge wrong and thought it was showing vacuum. The actual problem was that the fuel hose connector was leaking the air even after I replaced the O-rings inside. It appears now that the hose connector is worn and has too much slop after connected. I have proven this by disconnecting both ends of the air supply hose at the connector and used a piece of 3/16 brake line tubing to bypass the connector and now I have air pressure to the tank and a steady fuel supply to the motor. During this troubleshooting period, I installed an inline fuel filter just before the carb that allowed a visual inspection for fuel. Seeing fuel, I had suspected the carburetor float valve to be failing, so I ordered a carb rebuilding kit which included a new float and valve with the seat. BEWARE EVERYONE! The stalling problem became worse! After double-checking my carb rebuild, I took notice of the new float valve and observed a tiny rubber tip at the point. After trying the float valve by holding the carb upside-down, lifting the float and trying to blow into the carb fuel barb, it blocked as it should. But when holding the carb right side-up I could not get any air passage; the needle stuck into the valve seat because of that rubber tip. The original needle and seat was machined to equal tolerances and was of higher quality. The design using this rubber tip like an old drain plug is NOT a modern improvement, but a problematic repair. Having damaged the original float valve seat due to almost 70 years in place, I am now looking for a NOS replacement.
