olenavygoat
I'm attempting to hook up a 1968 40 hp Selectashift motor into a 1976 Eldocraft Eldorado I. The motor doesn't seem to match up to the book on color codes and of coarse the boat probably had a 65 h.p. motor on it originally.
Motor colors on dash end from motor are;
White 16 ga, then 2 black, 1 green, blue, red w/white stripe, tan, gray,brown that's hooked to the choke (all 18 ga), and a green 12 ga (hooked to "GEN" side of amp gauge) and brown 12 ga (hooked to "BAT" side of amp gauge).
On the boat wiring for the motor end there's;
All 16 ga and one each of; yellow, purple (temp warning), orange, green, blue, white, black. Then there's a 12 or 14 ga red wire.
If the dashes were similar it wouldn't be so bad but the dash piece with the motor doesn't match the boat dash. The boat doesn't have an amp gauge, or choke on the dash, The choke on the boat is a button you pull out on the throttle control lever box.
The only colors I'm sure about are for the temperature warning light (purple on boat, brown 18 ga from motor).
The repair manual I have says that from the starter switch is should be;
white is the solenoid
purple w/white stripe is choke
purple is temp. warning light (turns to tan at connector)
black is magneto to cut-out switch
orange is to generator (going from 14 ga at generator to 10 ga at connector
then another black magneto
Another issue I have is that the manual I have doesn't clearly show the letter diagram on the back of the ignition switch. I appreciate any tidbits that could point me in the right direction.
