Wiring diagram for 140hp Johnson 4 stroke
flicker
"I need a wiring diagram for a
"I need a wiring diagram for a Johnson 140hp 4 stroke engine. Motor will raise but will not go down. Relay pulls in, in the down position but no movement. Anyone have a diagram they could email as an attachment or mail to home address...thks"
"You probably toasted the &#34
"You probably toasted the "down" switch in the control. Suzuki only used a relay for the up function since the current draw is higher. The OMC control was never designed to take the current draw of the motor, therefore it will pop every so often. If I were you I'd add a relay for the down function."
