Hi Guys
I could use some help regarding a low TPS output signal.
The output V is less than 1.2v at WOT.
With the harness disconnected at the TPS the ref. V is 5 v which is good.
With harness disconnected and the ignition off I have 1.2 ohms at the TPS ground wire on the harness side which is good.
However, with the ignition turned on I have 25 ohms resistance at the same wire, which would be present when the motor is running likely causing an issue.
How can this be?
Thanks in advance
Jon Allen
How can this be?
Thanks in advance
Jon Allen
