Winterizing
flipflops
"ok guys whats the deal...i
"ok guys whats the deal...i under the recommendations of a friend, removed the fuel/water sep. filled the new one with 2 cyle oil and ran engine for a while in water and only got a little smoke out the exhuast.these are mpi's/inboards.in past boats i fogged from the top/carb with spray ormystery oil.and would get alot of smoke...besides not following the merc.manual recommendations what did i do wrong? how much smoke should i expect...? if i remove plugs and spray oil in there is that enough?"
can i spary oil into air intak
can i spary oil into air intake on top of motor???will it do anthing??will it harm sensors or anything? will it fog.?
"The 2 cycle oil was to lube t
"The 2 cycle oil was to lube the injectors. Yes, you can fog the engine thru the intake either with engine running or by grounding the coil output and just cranking the starter 10-20 secs."
"dont fog mpi motors, read the
"dont fog mpi motors, read the other threads, make the cocktail; fogging oil sticks to tips of injectors, you then have a miss in the spring and are spending lots of money on new injectors that wont clean up."
"anthony,
this is what the r
"anthony,
this is what the recommendation is for MPI engines from Mercury. I have never heard of just putting oil in the water separating filter.
Fogging Mixture
In a 6 US gal (23 L) remote outboard fuel tank, mix:
5 US gal (19 L) regular unleaded 87 octane (90 RON) gasoline.
64 fl oz. (1.89 L) Mercury or Quicksilver Premium Plus 2-Cycle TC-W3 Outboard oil.
5 fl oz. (150 mL) Mercury or Quicksilver Fuel System Treatment and Stabilizer, OR
1 fl oz. (30 mL) Mercury or Quicksilver Fuel System Treatment and Stabilizer
Concentrate.
New Fogging Procedure
1. Disconnect and plug boat’s fuel line from Water Separating Fuel Filter inlet.
2. Connect remote outboard fuel tank (with the fogging mixture) to the inlet of the Water Separating Fuel Filter. IMPORTANT: If the boat is out of the water, follow instructions for running engine on flush device as found in service manual for the engine being fogged.
3. a. Cool Fuel models: Start and run engine at 1300 rpm for 5 minutes.
b. VST models: Start and run engine at 1300 rpm for 10 minutes.
4. After specified running time is complete, slowly return throttle to idle rpm and shut engine off.
IMPORTANT: Do not run engine’s fuel system dry of this fogging mixture in the 6 US
gal (23 L) remote outboard fuel tank."
I was planning on spraying the
I was planning on spraying the fogging oil into the intake. Will that clogg the injectors. Does anyone have any experience with this.
