Uh-huh. Air plus moisture plus bare cast iron = RUST!
Jeff
Jeff, yes, is does equal rust...... however, the amount of rust or corrosion that could accumulate during the off season is paled by comparison to that which occurs during the boating season.
Depending on how the anti-freeze is introduced, there can be some issues regarding dilution.
For the Raw Water cooled engine, if we drain the block first, re-install the drain plugs, and pour the anti-freeze in through the thermostat port, we stand a much better chance of no dilution. In fact, this actually works very well.
For a single impeller raw water cooled engine, there's an issue with the T-stat housing and by-pass porting when one of these Camco Winterizing kits are used.... or a home made version of this!
The user sees anti-freeze exit the exhaust, and thinks that all is OK due to his misunderstanding of his cooling system.
This is the I/O version.... there's a I/B version also.
Not sure how this would work with a dual pocket sea water pump.
For an engine with a Closed Cooling system and a raw water exhaust system, there does not seem to be an issue.
Given 3 or 4 gallons, what goes in is what comes out, and is fairly non-diluted.
I've discussed this numerous times.
I've also heard from people who have checked afterwards, and have found diluted anti-freeze in their engine blocks.
It's all about the raw water cooled engine T-stat housing and the diversion or by-pass within the T-stat housing.
My advice would be to NOT use this method!
Or completely drain first if you're hell bent on doing this.
Otherwise, you can rest assured that just plain old air will never freeze and expand causing expansion damage.
The minor amount of rust scale within the cooling jackets is nothing compared to a cracked engine block.
