marshallman
Just bought this 2000 Bayliner
Just bought this 2000 Bayliner 1802 Capri. Dealer says to winterize add stabilizer to tank and let it run thru the engine which I did. Then remove plugs and spray fogging oil into cylinders. Anything else? Never had to winterize before since there is not much of a winter in Miami FL. Also had to adjust idle to 675 RPM no load is this correct? Was idleing at about 1200 RPM with no load. At 675 RPM Idles rough should I crank it up a little more? Any advice would be appreciated. I have not owned a boat in 20 years. Thanks in advance.
