"Thanks for the previous help,
"Thanks for the previous help, I still am trying to figure out if it is a 302 or 351. The main question I have is, where it does not have a closed cooling system, do I need to refill the engine with antifreeze after I drain the block and manifold and remove the lower hose on the water pump, or is just draining the water out sufficient. I realize I need to fog the cylinders, and change the oil in both the engine and the drive unit, as well as lubricate everything. I have heard advice suggesting you don't need to refill with antifreeze. I am looking for advice."
