................ Unless you are going to disconnect the raw water intake ,with the valve closed off to the outside sea water and introduce your RV anti freeze from this point. I have done it this way for years and never had a problem. I do have a question for you,though, since you are going to leave it in the water, how are you going to keep the bilge pump from freezing up thru out the winter?
If you pour anti freeze in the bilge and run it thru the pump that will work fine until it rains or snows, then the bilge pump will pump it all out and you'll be left with fresh water in the bilge and pump which will then freeze solid and the next time the pump tries to come on ....goodbye pump. Just wondering.
