Hello,
With a EFI moteur (mercury 60hp 2013), what is the easiest DIY technique to protect the cylinders and rings for the winter season:
1) Inject storage oil through the air filter (will have to find where to spray)
2) Run the motor with a oil\gaz mix for a few minutes (bypass the main tank with a portable gaz tank). Bad for injector??? Yamaha have a special oil for this process.
3) Remove the spark plug and spray wd-40 or storage oil (bottom spark plug hard to reach)
To my question a mechanic told me ''Sometime you owners overkill the process by doing to much''
Thank for advice
Normand (Québec)
Thank for advice
Normand (Québec)
