anchorthis
"I just think I winterized my
"I just think I winterized my 115 Rude (1982). I checked the lower unit...yep weeped fresh gear oil...no water. But the top check screw when out does not show any oil...."shouldn't it be filled to that point?"
Also, other steps I did where adding fuel stabilizer and then Fogged the 4 carbs. Just wondering though...when I sprayed Evinrude fogging oil into each carb while at about a 2500 rpm I sprayed for about 1 minute per carb. At first the engine revved up quite a bit. Is that normal?
After smoking out much of my neighborhood I shut the engine down and called it DONE. Does that sound ok????????"
