2002 Honda 115 BZBD
Motor has developed a problem of not wanting to start when warm(will turn over fine).
Took to dealer where they replaced relay per service bulletin. Has made no difference.
Here are troubleshooting steps I have done:
1. Take boat to lake.
Pump fuel bulb until hard.
Motor starts and runs fine, run motor 45 min(idle to wide open)
Turn motor off with key.
Try to restart, motor will crank but not start
Fuel vs Fire: Spark plugs are dry, Mechanical fuel pump is pumping fuel,
no sound from elec fuel pump when key turned on.
Check fuses
Check all connection's
After 40-45 min, Motor starts and runs fine.
15 min boat ride to trailer,runs fine.
Turn motor off with key, Would not restart
2. Next trip to lake:
Before launching boat, check fuel system
Turn key on hear elec fuel pump
remove plug on back of fuel pump good flow and pressure
Test voltage to pump, (12 volts noted)
Take boat out for 35 min, back at trailer same thing
do not hear elec fuel pump, no flow at pump
Test voltage to pump, (12 volt noted)
Need help with next step, vapor separator vs fuel pump?
Check fuses
