Will not run
puppychow
My 1967 9.5 hp johnson will not run if i prime the carb it will try to start but no go.there is fuel to the carb but i don`t see any fuel going into the bowl. I took the carb apart and the float looks ok the needle was sticking but i freed it up that seens to be ok any ideas . Thanks. Puppychow
Have you taken the drain plug out of the float bowl, pumped the primer bulb and see if fuel comes out??
