Started up Merc 383 with Alpha ss drive and no water out of thru hull exhaust. Took hose off cooler and is pumping very little water. Pulled off lower gearcase and hooked up garden hose to copper water pipe in upper gearcase and lots of water out of exhaust tips. Check water passages in lower gearcase and are open. Removed impeller housing and impeller looked ok. Installed new seawater impeller kit and still won't pump water, Lower unit is in big tub of water because muffs will not work on a ss drive. Any ideas? I have installed probably 15 impeller kits over the past 25 years with no problems. Does the lower case need to be deeper in the water? Water is 2 inches below ventilation plate. Thanks
