Why do I have the loudest outboard
gone_postal
"98 Johnson 90hp - 60* V4
"98 Johnson 90hp - 60* V4 Looper
A few months ago it sounded like I had a cam in it - not necessarily a bad thing if it actually did - turns out it was in need of a rebuild. At idle I was only running on 3 cylinders.
Well, after the rebuild I was really expecting it to be much quieter. Don't get me wrong, it's quieter - definitely smoother - but still seems that it's the loudest 2 stroke at the ramp. I have seen other motors w/ the same engine cover as mine (meaning they're at least the same generation motor) and I haven't found one yet that is as loud as mine (although I realise some could be crossflow - not sure if they're quieter by nature). I actually have people turn and look when I start my motor. Yes, mostly are 4 stroke owners, but back to the point, is this normal for this particular engine?
Yesterday was the icing on the cake for me - a guy rolled up in a boat that had at least a 15-20yr old Johnson V4 120hp on it and it was quiet as hell!! I was really expecting that to be louder than mine - it even smoked less! So, it just makes me wonder if something is by chance wrong? If not, I'm fine w/ it. I have great compression, etc"
loud like exhaust (is your
loud like exhaust (is your prop all the way in the water)
loud like engine noise(engine cowling missing the foam on the inside)
"LoL on the prop - yes, it&#39
"LoL on the prop - yes, it's in the water.
Also, as for the cowling - I removed the foam, installed two layers of dynamat and then put the foam back on over the dynamat - that's how much it bothers me. For what it's worth, the dynamat did very little. A guy at work said he used that great stuff expanding foam on his, but I'm not gonna go that route - seems too extreme and too much of a PITA to get it just right b/c of minimal clearance inside.
It's not a mechanical noise - more exhaust to me. I guess it's just how it's meant to be. Maybe next time out I'll take a short video and post it on YouTube."
"just run it and give them som
"just run it and give them something to look at
when you take off(no clip art with middle finger)"
