i have a new engine with new manifolds, spacers and risers. i am getting water in the oil and i traced it to the exhaust. the manifolds are wet inside the jackets at the point where the maifolds bolt up to the heads. when i run the engine on a stand with just the risers, boots and elbows in place i am getting water. i ran the wngine yesterday with the boots and elbows removed and it appears there is water coming out of the large center exhoust port hole.
my understanding was that the just exhaust comes out of that hole and the water exits from the holes above and below that center hole. and they all combine in the boot/elbow and exit through the y pipe etc...
am i correct with that?
so if my understanding is right then there must be someplace inside the manifolds/spacers/riser area where there is water intrusion, does that sound right or is the exhaust operating as it should?
i know that due to the cam profile(standard Marine cam) the exhaust port is open momentarily on the downward stroke of the piston and it could suck water in if it is close enough on the manifold but i am trying to figure out if this issue is reversion or if ther is a problem in the exhaust, BTW, i did the acetone terst and it passed.
i feel like i am chasing ghosts with this engine and i am no closer to a resolution than i was 2 weeks ago.
