which outdrive ?
hi all thanks for all the help so far ......
i have 1988 4.3 mercruiser im putting into a bayliner, the drive is a alpha 1 and so is the gimble the drive i have is in a poor state of repair and am looking at replacing it as it may be cheaper than fixing up the one i have
thye question is can i put a alpha gen 2 drive on the alpha 1 gimble and can i put different gear ratios on ?
ive been offered a gen 2 with a gear ratio of 2 to 1 will this work ?
the prop i have is a hive five stainless 13.25 x 21 pitch
i think the gear is 1.84
any help from the gurus would be fantastic
steve
as a direct bolt on ,No.The lower shift shaft in the gimbal would have to be changed. The mounting for the rams is also different.
