footbrake
Finally got my mechanic over to change the engine oil and filter(2.5 120hp 4cyl.) and to check and get the outdrive fluids up to snuff. After having started the boat on the trailer with muffs of course, everything seemed fine and dandy. Had good oil pressure,40lbs., temp. about 160-180. ran it about 15 minutes and shut it off to check the points and such. Here's where it gets interesting. I went into the house for about 5 min. and came out to find the bilge pump pumping water out and the drain in the back pouring water out. The water was cold so I figured it didn't come from the motor. The bilge area was wet. If there was water in the boat, why didn't it start coming out before this? there must have been a lot of water somewhere for the bilge to kick on. what's going on here? thanks-Russ
