gone_postal
"1998 Johnson 90hp - J90ELECM
Before anyone asks - YES, it's worth it to me for the 5mph I'd gain!! Can never be too fast....
Anyway, I want to convert this to a 115. After studying many parts fiches, the ONLY differing parts I can find are the heads. The carbs, throttle bodies, rotating assembly, ignition, etc are all the same part #s. Luckily I stumbled across a set of used 115 heads on Ebay and got them for cheap. I haven't compared them to my 90's yet, but I'm assuming they're shaved to result in higher compression.
Now, if this is the case, surely the motor would want more fuel right? No way a set of heads increases 25hp in a motor this small? Unless the 115 is overrated or the 90 is underrated. BUT, if the carb #s are the same, then wouldn't that mean the jets are the same too? I don't see jets available separately, so I can only assume they come preinstalled.
I have OEM service manual and it shows initial adjustments (as far as turns out, etc) being same between 90 & 115.
Any ideas? Is there any definitive place that I can find out for sure if the carbs differ at all? (or anything else for that matter)"
