Hi everyone...I'm new here.
I have a 2011 2855 MAG350 MP Bravo III.
It was a left over from 2011, so I started using it in the summer of 2012.
I put approx 30-40 hours per year on the engine.
Use it in Brackish water.
Raw water system
Manifolds are Dry Joint.
Two questions here:
1) When will it be time to change the Dry Joint manifolds/risers?
2) When I use my IF temperature gun, what temps will be normal at my normal cruise with 4 people @ 4000 RPM's?
My temperature gauge is a steady 180. It has been that way since I purchased the boat. I had changed the thermostat and there is no change. When I use the IF gun on the thermostat housing, it shows approx 160-175 depending where I aim it.
Thank you!
Mike
Raw water system
Two questions here:
Thank you!
Mike
