"I will start off with a descr
"I will start off with a description of the problem. The 3.0 runs great for the first 3 to 5 minutes but once the motor gets warm I start to have trouble. When cruising at 3800 rpm with the motor warm it starts to miss (SOUNDS LIKE AN ELECTRONIC MISS BUT I AM NOT 100% SURE) and it drops rpm. Sometimes you can get back in the throttle and other times you can't. Usaully you can cruise at under 2700 rpm no problems but it cuts out there once and awhile also.
1. The choke is not sticking on. I have ran without the arrestor to check.
2. I have tried unplugging the ESA for the shift cables ( not sure if that is the spelling)
3. I have new fuel filters in the pump and the carb.
4. I have new points, condenser and the other parts near them in the distributor. new coil, new cap, new wires, new plugs.
5. The timing is right.
What am I missing... This is drivng me nuts... Any thoughts would be great."
